im building a 2.4l ld9 its a turbo project for a swap where can i get upgraded bearings,and other internal parts ? i already have the pistons ,rods ,and valves. but im cant find any thing else. anybody know ? also a oil pump . or will stock be ok i hope to be running 15-18 lbs on this engine to start .
13's or blowning it. one way or the other!
hey, you can get a crap load of stuff off of.......... www.importperformanceparts.com
they have everything for cavaliers, especially if your putting a turbo on your car. they have tons of internal parts, like port n polished heads/ pistons/ cams/ etc...................... good luck
If you wanna run that much boost then your stock oil pump wont last.. You'll have to do the 2.3 oil conversion.. Im pretty sure. Hopefully somone else can back me up on that.
