Starter For 96 Cavy 2.2L - Performance Forum
Monday, September 12, 2005 3:11 AM
ok i not sure if i should put this here or in the general forum but i think its best to be here......
i have a 1996 2.2L cavailer and i need a starter for it and i want to put in a performance starter in and i need to know what kind i should be putting into it, i dont want to buy and find that i bought the wrong part....if any one can help me it would be great....
procrastination is like masturbation...its awesome till you realize that you just @!#$ yourself....
http://members.cardomain.com/slacker2110
Re: Starter For 96 Cavy 2.2L
Monday, September 12, 2005 5:21 AM
just go to autozone and say you want a starter for your car. then buy a haynes manual and install it yourself
Monday, September 12, 2005 8:29 AM
the only thing you can get is OEM replacement
Monday, September 12, 2005 8:36 AM
wrong! click here for your performance starter: CLICKY
Monday, September 12, 2005 10:57 AM
^^^ actually that looks to be the 2000+ starters....
they take less amps to start the car on startup....are slightly smaller and same cranking amps...
unless you are so high in compression you need a superduty starter, the 2000+ starters will get the job done more efficiently than the 95-99 bigger starters.
Monday, September 12, 2005 12:52 PM
i hate it when people who attempt to prove me wrong are proven wrong by event. thanks buddy. lol
Tuesday, September 13, 2005 3:20 AM
what about these....anyone know if these will work?????CLICK
Tuesday, September 13, 2005 3:22 AM
oh... and if it matters i have a 5-speed
Tuesday, September 13, 2005 3:32 AM
Stop and think for a minute.
Why do you need a "performance" starter?
Most likely your mind will draw a blank. When it does, remove your current starter and have a friend take you down to the local parts store and pick up a starter made for your car.
The 2000+ starters are significantly more expensive than the older style and they are only like 8lbs less.
Besides, according to your registry you are going to be swaping to a 2.4l and adding a turbo. Why invest in the current motor that your going to ditch?
Tuesday, September 13, 2005 4:16 AM
CustomCavy, those starters are for smallblock Chebbies. My experience with the OEM gear reduction starters in other applications is that they seem to last longer than the older OEM direct drive starters. When the starter in my 93 died, I called a wrecking yard and had the 2000+ starter delivered for cheap $$, maybe $15? It's substantially lighter than the old style unit. Also, many of the "race only" lightweight starters don't last very long on the street.
-->Slow
