GM cams for ECOTEC 2.2L - Performance Forum
Saturday, September 10, 2005 10:51 PM
I was looking to get the GM cams with the adjusters. i wanted to know if anybody was running them and what luck you have had. and i do plan to boost it. I was told to wait till I had a kit.
Re: GM cams for ECOTEC 2.2L
Saturday, September 10, 2005 11:17 PM
What GM Camshafts are you talking about?
Sunday, September 11, 2005 12:22 AM
ahem... level zero motorsports cams.
Sunday, September 11, 2005 12:27 AM
Spotabee Racing wrote:ahem... level zero motorsports cams.
When he says "GM Cams" I'm thinking he's talking about camshafts sold by GM, not a seperate company...
Sunday, September 11, 2005 12:32 AM
i know. but i wanted to introduce a... "better" idea.
Sunday, September 11, 2005 12:45 AM
I wouldn't consider LZM camshafts a better idea...(hence the LZM Group Purchase)
If you want good camshafts, read the ECOTEC Build Guide for part numbers and references.
Sunday, September 11, 2005 5:14 AM
im running the gm performance supercharger and im very impressed on theyre service and how well it installed and runs. gm has some great performance addons.
Sunday, September 11, 2005 6:16 AM
In Europe we have a lot of good cams for the Ecotec, cheap regrinds as well (Pipercams)
Sunday, September 11, 2005 7:40 AM
Last I checked, GM only sells cam blanks.... you need to send them somewhere to have them ground anyway. The only advantage to this is that they are more reliable than reground stock cams because they haven't been spray-welded. If you buy GM cams all you are getting is a cam that hasn't been cut yet, you still need to sent them to Crane, Comp Cams, Elgin, wherever, to have them ground to your specs.
To be honest, with cam grinding being fairly cheap, I don't believe in buying off-the-shelf, one-size-fits-all cams. Its much better to call up a company that has been doing cams for years, and say, this is my compression ratio, i'd like a powerband between X,XXX and X,XXX rpm, etc, etc, and have them come up with something. So, yes, buying the blanks from GM is fine, but you can't just install them like that, or your car won't even run, actually, if they leave enough excess material on the lobes, they won't even fit in the head until they're ground down.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
Sunday, September 11, 2005 12:41 PM
they are in the 2005 Performce book i read the guide. they are percut. and gm says that they are for a turbo or NA. if i had the book in front of me i would give you more info. and the website doesn't have them. also how will having the neutral balance shafts. i was i could give you guys the numbers.
it would be funny to see someone try to run the blanks, it would make me laugh.
Sunday, September 11, 2005 1:11 PM
RAKSJ04 wrote:they are in the 2005 Performce book i read the guide. they are percut. and gm says that they are for a turbo or NA. if i had the book in front of me i would give you more info. and the website doesn't have them. also how will having the neutral balance shafts. i was i could give you guys the numbers.
Ok, I personally have the phsyical handbook and the first time it mentions changing your camshafts is in the 400-600 HP section. This what it says:
GM Handbook wrote:Camshafts
GM Performance Parts offers a matched pair of high performance cams (part number 88958636 and part number 88958637). These cams require the Bates race valve springs and retainers to avoid coil bind.
So I don't know where you got they they offer a certain turbo one and N/A one...
Do what Scarab said and find out what exact kind of gring you need and what you are looking for in your camshaft.
Sunday, September 11, 2005 1:29 PM
i am having my dad bring home the GM High perforumance book monday. i will post up the numbers, part, lobe and other stuff. and i will scan it to.
Sunday, September 11, 2005 1:56 PM
RAKSJ04 wrote:i am having my dad bring home the GM High perforumance book monday. i will post up the numbers, part, lobe and other stuff. and i will scan it to.
I think me and you are talking about 2 different books. I think you have the GM High Performance Catalog and I have the ECOTEC Performance Build Book.
I think GM High Performance does have camshafts...I heard of 1 person getting it but it's not really popular.
Sunday, September 11, 2005 4:37 PM
running on blank cams... lmao. i wonder what would happen. wouldnt all the valves just be held open if you did that?
Sunday, September 11, 2005 4:56 PM
Those cams advetized by G.M. don't even exist. When I looked at trying to get them I was told the manufacturer doen't have any stock availible. After more phone calls then I'd have cared to have made I found out that Crower grinds the cams fro G.M. and that the part numbers listed are for some fairly large gring cams. Crower sells like 8 different grinds for the ECOtec and they've been grinding cams for like over 50 years
so I'd recomend checking them out. And Mr.Crower is a great guy to deal with. He quoted me $400.00 for both cams shipped to my door.
Good luck.
Sunday, September 11, 2005 7:14 PM
$400 isn't bad. second question, i was told that if i ran cams that are made for a boosted engine in a N/A engine you would get a lose. because over lap is good for N/A and bad for boost.
Sunday, September 11, 2005 8:30 PM
RAKSJ04 wrote:$400 isn't bad. second question, i was told that if i ran cams that are made for a boosted engine in a N/A engine you would get a lose. because over lap is good for N/A and bad for boost.
Exactly. N/A cars make power with high duration (causing more overlap).
Monday, September 12, 2005 10:58 AM
could i put a turbo cam in but wit the adjusters change the timing to work without a turbo. or is it too much work to mess with??
Monday, September 12, 2005 7:56 PM
i can get the GM stage 1 performance cams that they advertise in the GM performance parts hand book heres the part number for them 88958648....my price is 450 but they list for higher than that....i get all GM parts for 10% over cost
I AM the man from Nantucket
Tuesday, September 13, 2005 5:08 AM
/\ /\ /\ Heres what service parts costomer asitance center said when I just called them.
Part #88958648 is a ship direct part, sorce has no stock availible. No delivery date is availible, part is non-returnable. Then when I checked the price it told me standard dealer price is $472.83 trade cost is $574.32 and list price is $675.48. Now I don't know about where you work but down here parts employees pay 10% over dealer cost
which puts the price at $520.12 plus tax. And according to G.M. as of 8:03 this morning
none of these cams exist. Thats why I offered Crower as an alternative since they are the company G.M. uses to grind the cams in there ECOTEC race cars. If G.M. uses them for the factory backed raceing program they should do just fine in our cars too.
Tuesday, September 13, 2005 8:19 AM
thanks for your help
Tuesday, September 13, 2005 4:39 PM
i found these on JBP
http://www.jbodyperformance.com/new/PartDetails.php?partId=288&catId=288&catName=JP0288
it looks like they come with the adjuster and they will grind them for you at the same price at 559usd with adjuster isn't bad. i have no idea what grind to have. i know what the numbers mean, but i don't know how it will help me. what is a good grind for the ECOTEC
Tuesday, September 13, 2005 5:13 PM
RAKSJ04 wrote:i found these on JBP
If you read ECOTEC Build Guide I have that camshaft set listed and I have other ones listed.
No, the adjustable cam gears do not come with it, I should know cause I have them and I asked before I bought them and they just said it was for a picture and that it's not included.
A good grind depends on what you're are looking for, do you mind throwing codes? Are you boosting or going n/a?
Tuesday, September 13, 2005 5:43 PM
i don't know which way i am going yet, N/A or boost. i don't have the money for any way yet.
Tuesday, September 13, 2005 5:54 PM
RAKSJ04 wrote:i don't know which way i am going yet, N/A or boost. i don't have the money for any way yet.
Then the best thing for you to do is stay with a stock camshaft
