2200 rocker arm pedestal question - Performance Forum
Wednesday, September 07, 2005 10:42 AM
Ok... so I picked up another 2200 head... which I plan on doing a P&P on... I'm also planing on doing the crane roller rocker upgrade...
One question though.
When I pulled the factory rocker arms off, I noticed a groove machined into the pedestal. Now, I'll assume that's to align the factory rocker arms with the valve tip.
But for the Crane rocker arms, it's self aligned at the tip of the rocker arm correct? So, how is the base of the Crane rocker arm going to sit with a groove in the rocker arm pedestal?
Thanks all!!
Re: 2200 rocker arm pedestal question
Wednesday, September 07, 2005 10:48 AM
The studs that screw into the head won't let the rocker even get close to that groove
the stud is cone shaped but the flat portion will cover the groove in the head, and will taper enough so the rocker doesn't bind on the stud
the only thing is the size... if you try to install the rockers and the stud doesn't fit, call howell and they'll send you the correct stud.
there are different heads from year to year on the 2200 OHV altho the differences are miniscule (no effect in performance numbers) certain parts need to be different sizes (the studs for one)
Wednesday, September 07, 2005 10:53 AM
TheFlyingSquirrel (PJ) wrote:The studs that screw into the head won't let the rocker even get close to that groove
duh... I forgot about the studs.... I've got the part number sitting here right in front of me too, must be blonde today or something.... thanks again
Wednesday, September 07, 2005 10:58 AM
hey TheFlyingSquirrel, what would be the correct part numbers for the '98 or '99 head?
'99 2200 LS CX1 Sport
Wednesday, September 07, 2005 4:07 PM
Wes, just get the Crane Roller Rocker set from Howell Autosports, they come with the studs you need.
Wednesday, September 07, 2005 10:53 PM
^^ they dont always come with the wrong studs..
I think I was just one of the lucky few who got the ones that dont fit
phlatcav got the wrong size studsin his pack too
he has the part number.. my computer isn't running right now (i'm on a friends laptop) as soon as I get it online I'll post the part number
Wednesday, September 07, 2005 11:15 PM
Haha, my computed does not work either so Im using my girlfriends I have the part number just not on me. Sorry.
PJ ill be back online saturday
Thursday, September 08, 2005 4:56 AM
Here's a link to the Rockers
Thursday, September 08, 2005 9:46 AM
^^ that link is for 1.6:1 rockers, is there a kit for something bigger?
like 1.7:1 or 1.8:1?
I'm looking for more than an 8 hp gain
Thursday, September 08, 2005 12:13 PM
The 1.6:1 rockers raise the amount of lift from 0.432"(maximal) stock to a true 0.4608". The Crane and Comp rockers are ratio accurate, while the stock GM are not. The increased ratio also increases the ramp ratio, so that the cylinders fill sooner and quicker.
As far as the 1.7:1+ ratio rockers see this post. HotRodV6 and others have been working on this issue along with other valve train issues in this series.
