i don't know why it is so hard to start my car when it is warm i have intake headers exhaust. had venom modula and jet pcm but had the problem when i got the headers and exhaust really is a problem any help is great.
i dont really know. mine just takes a second or 2 whens its warmed up.
Chances are your header is heat soaking your starter. Try some insulation on the header.
OP wrote:Chances are your header is heat soaking your starter. Try some insulation on the header.
depends on the car...
2.2 ohv... yup, right on...
2.2 eco, or 2.4 or 2.3... headers no where near the starter...
might actually be time for a tuneup if you got miles.
if your header is heat soaking your starter, there is always the option of having it ceramic coated...
When you say it is hard to start, do you mean that it cranks for a long time before it starts?
If this is the case, check your fuel pressure regulater hose. Pull it off with the car warm and not running, if gas comes out you need a new regulator.
Or it could be just like my car, crank it for a bit and tap the gas, starts right up when warm.
Now if it dosen't crank at all then I would say that it is heat soak.
'99 2200 LS CX1 Sport
i will try insulation but what kind and where is a good place to order it
and yes this is what i mean. but with the fuel pressure regulator which is the best for normal use but soon to be hopfuly boosted?
antonio mcintyre wrote:i will try insulation but what kind and where is a good place to order it
You can order it from Jeg's
jeg's? i don't know what you mean?
antonio mcintyre wrote:jeg's? i don't know what you mean?
read the FAQ,. top of the forum, jegs is a website.... the links are posted at the FAQ in the top of this forum...
jegs is a car magazine u can order all kinds of stuff from them
A/C what's that? race cars don't have A/C... as I don't have A/C lol
