New Head Is In - Performance Forum
New Head Is In
Sunday, August 28, 2005 11:41 AM
Hey there guys got the head back in my car after the port and polish valve job and resurfacing but i think i made a mistake its an ohv does that need to be timed like a ohc would be? I know thats a kinda noob question but lemme know.
Re: New Head Is In
Sunday, August 28, 2005 12:16 PM
as long as you didnt remove the cam or the crank, the timing chain and those two parts are in the block...
so you shouldnt have to time anything.
Re: New Head Is In
Sunday, August 28, 2005 12:19 PM
yeah i got it all back together and it just sounds like crap sounds like something is knocking and i dont know what it could be... i did have a valve job done so they were out of the head could that have anything to do with it?
Re: New Head Is In
Monday, August 29, 2005 6:08 PM
did you adjust th rockers correctly? could you discribe the sound a little better ...does it speed up when you blip the gas etc etc.
Re: New Head Is In
Monday, August 29, 2005 6:21 PM
yeah is it a knock or a click?
Re: New Head Is In
Monday, August 29, 2005 7:57 PM
Michael Woolever wrote:yeah i got it all back together and it just sounds like crap sounds like something is knocking and i dont know what it could be... i did have a valve job done so they were out of the head could that have anything to do with it?
do yuo by chance know the angles?
if the angles of the valves dont match the head, it could be the seat/valve tappin a bit.
like said, knock could be the rockers...
Re: New Head Is In
Monday, August 29, 2005 8:05 PM
did you drop any of the push rods?
Tach Out Motorsport
Http://www.team-tachout.com/
Falmouth,VA
Re: New Head Is In
Monday, August 29, 2005 10:56 PM
if it's knockin, let it in. if it's tapin, readjust.
Re: New Head Is In
Tuesday, August 30, 2005 2:53 PM
I dont really know how to describe the sound its loud and doesnt sound like all of the valves. I didnt move any of the push rods i kept them with the rocker that they belonged to and in the order i took them out. However they were left were others could have moved them around not that anyone did that i know about anyway. my head was out for almost two months so that left a lot of time for them to get moved. Felpro didnt have the top end set in stock i guess at least thats the story i got. is there anyway to tell just in case if i did install them backwards? What would happen if they were installed wrong i dont knwo much about that. the sound seems to go away at a higher idle. I suppose it could be the exhaust too because i know that needs to be replaced. Could it be that i am hearing the sound louder because of the bad exhaust?
Re: New Head Is In Making Noise
Thursday, September 01, 2005 6:24 AM
Just wodering if anyone had any more ideas? Tried to get you guys some more info. Let me knwo what you guys think.
Thursday, September 01, 2005 9:36 AM
Are you sure it isn't an exhaust leak? I notice a sound that sounds sorta like lifter tap, however it isn't coming from the head, it is coming from my crank pulley. That could be it...
Thursday, September 01, 2005 11:03 AM
Dude at this point I dont know what it is.... I knwo the exhaust is bad and needs to be replaced and anyone knows that the whole flex pipe is crap anyway but... thats another story all together.... thanks for giving me something else to check.
Thursday, September 01, 2005 11:08 AM
did you just P&P the head or did you get a new valvetrain as well?
Thursday, September 01, 2005 11:18 AM
Phlat did you find a place for your P&P
Look Im Premium Now Give Me More Post....
Thursday, September 01, 2005 11:19 AM
yes
Thursday, September 01, 2005 11:23 AM
wheres that
its not in louisville is it cause i guess if im building mine up i mihgt as well follow your examples.... i was planning on taken mine to mt.sterling if i cant find a place close.
Thursday, September 01, 2005 12:13 PM
Shaune Drake wrote:wheres that
just start looking around for machine shops...
Thursday, September 01, 2005 12:22 PM
port and polish and vavle job didnt replace the valves though... i took a closer listen and it sounds like its comming from the intake manifold area... gonna look at it agian and see if i missed a bolt or something.... will go from there.... i had the port and polish 3 way valve job top end gasket set new bolts for $310
Thursday, September 01, 2005 12:26 PM
Did you open the valve cover since you put it back together to see if everything is looking right? maybe a rocker roller is off the pushrod. 3 years ago, when i knew nothing about cars, and i replaced my head gasket, following the service manual, i put it all back together tightened it down, and i didn't know how to adjust the valves, and rockers cause 1 fell off the second i started it. and the exhaust valve on one of the cylinders wasn't opening at all. drove like @!#$. haha. opened the valve cover and it was immedialy apparent what was wrong.
Not saying that might be your problem, but, worth looking in there again.
Thursday, September 01, 2005 1:44 PM
yeah i have had the valve cover off agian.... you guys keep talking about adjusting the rocker arm is there more to it than just making sure the bulb is in the rocker where it blongs and the other end is pusing down on the valve and spring/
