would a 2.3 quad4 be a better prj than a 2.4 dohc? - Performance Forum
Sunday, August 21, 2005 11:53 AM
both engines/harness/tran are easy to get i'll be only paying a little more for 2.4
which of these engines would be Better to work up?
i want to fit it in my 2000 cavalier 2200 ohv
and another question are 2.4 and 2200 carry the same fuel injectors?
Re: would a 2.3 quad4 be a better prj than a 2.4 d
Sunday, August 21, 2005 11:58 AM
2.4
Sunday, August 21, 2005 12:26 PM
i thought the 2.3 had way better torque..
Sunday, August 21, 2005 1:22 PM
2.3 is a better project motor then a 2.4. The things you can do to a 2.3 from a HO or w41 alone... I went from 2.2, to 2.4, to 2.3 & that's where Im staying lol
Sunday, August 21, 2005 4:09 PM
the Ho/W41 got more power. Even the 92 lo 2.3 got more power than a 2.4.
Gilles
2.3 Ho
Sunday, August 21, 2005 4:59 PM
I know i keep bringing up the reliability issue, so correct me if i'm wrong. Didn't the quad four (the w41 in particular) have a massive amount of more head gasket/head problems than a 2.4?
Sunday, August 21, 2005 5:05 PM
that's why you just get a newer Headgasket, they corrected the issue a little too late to save the image of the Quad4, that's why the "Twin Cam" was born. the Quad will always be the performance 4 cylinder of the GM lineup IMO.
Sunday, August 21, 2005 5:47 PM
So it was the head gasket, not the head that was the problem?
Sunday, August 21, 2005 7:16 PM
yes..hes right..if you can get ahold of a HO/w41 quad just go ahead and change the headgasket before you put it in...you should be fine and youll be much happier in performance
and im still waiting on an explaination WHY he suggested that.......
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
Sunday, August 21, 2005 9:36 PM
simply uninformed. that's all.
Monday, August 22, 2005 2:10 AM
Btw, the biggest problem was not really the head gasket, it was the driver. Yes the head gasket was weak but I did a full year of racing with a Gm head gasket and never had any problem. I do use Fel-pro now.
The engine need air, if you sit in traffic, you'll blow it up unless you have a switch for the radiator fan.
Gilles
2.3 Ho
Monday, August 22, 2005 2:28 AM
ok what i can get is a stripped w/o throttlebody intake, distributer, out of a poniac grand-am or grand something.
i think it would be a LO. is there anyway to findout from the serial # on the engine which is LO or HO?
Monday, August 22, 2005 2:48 AM
Actually are 2.4's "Twin Cam" OR "DOHC"
i never seen one lol
Monday, August 22, 2005 6:07 AM
SundayNight PegCity wrote:Actually are 2.4's "Twin Cam" OR "DOHC"
Both, lol. A better question is "which of these am I going to be able to figure out how to swap into my car?" The 2.3 requires rewiring the car to OBD1, and you may run into troubles with the BCM since your car is a '00. Either way, you'll also need a tranny as well.
For Sale:
Monday, August 22, 2005 11:26 AM
the cooling is the biigest prob, would an aftermarket ecltricall fan, and larger radiator, and better thermostat to flow more fluid ,help for sitting in traffic, or is there anything eles that we can do to cool off the 2.3 block???
Monday, August 22, 2005 11:31 AM
yea, i remember at spring break i was sitting on the strip waiting to go and my car got pretty hot, from just sitting there but it's fine once i start getting air to the radiator....
NEW SIG COMING SOON FOR 07'!!!
Monday, August 22, 2005 11:37 AM
I just kick on the AC so the fan runs, it cools the motor down, suprisingly enough. Then its back off when I'm moving.
Monday, August 22, 2005 10:11 PM
yes....you can do this..however a cheaper and just as affective way that the rest of us use is to wire a switch to the fan...so when were sitting still we can kick the fan on manually...it cools right down ..comes in handy at the track
