Need JE Piston Rings!!! - Performance Forum
Thursday, August 11, 2005 2:06 AM
Bought some Je pistons used and went to replace the rings and factory ones wont work has to be straight from JE thing is i have no idea what to ask for since i dont have any of the old paper work, they are stock compression stock bore pistons for a 99 2.4 can anyone help?
Re: Need JE Piston Rings!!!
Thursday, August 11, 2005 3:21 AM
I don't think you need any paper work. Call them and tell them your situation and that you need piston rings for a 2.4 motor on stock compression (10:1 I believe).
Thursday, August 11, 2005 3:45 AM
9.5:1 pre 98 9.7:1 99+ if I remember right
LE61T PTE6262 Powered
Tuesday, August 16, 2005 3:55 PM
hhhmm r u sure thats the compression and they said they needed to know the size of the ring and the bore size? Any one help me with that one?
Tuesday, August 16, 2005 4:30 PM
gm_guy _ wrote: stock bore pistons for a 99 2.4
I would say send them your pistons to have them check it out. The last thing you want would be a blown engine because you guessed on a measurement.
My Car
