man has anyone had such a hard time getting the bolt where the coolant tank is out. After moving the tank i used 2 different extentions, one longer one but that didnt work so i thought i'd use a shorter one for more leverage but still NO! I even put wd4 on it 2 times and let it sit and doesnt budge. do you guys have any suggestions?
2.4 engine mounts
<img src="http://www.j-body.org/registry/jay32m/personal_pic.jpg">
where can i get pb blaster?
impact wrench. I had the same problem. when i used my 3/4 socket wrench and a 3 foot pipe for leverage I ended up snapping my socket wrench (thank god for craftsman warrenty) then i got pissed and borrowed my buddys impact wrench and it came out like it was nothing
J-Bo driver once again.......
16...
15...
14...
13...
12...
11...
10...
9...
I got PB Blaster from Autozone I believe. I would also use an impact on it if you have access to one. If not squirt the bolt with PB, wait a minute for it to soak in and then try to get the longest bfreaker bar that you can to break the bolt loose. You could also put a longer pipe on the end of the breaker bar for more leverage. I wouldn't use a socket wrench to get the bolt loose because the gears inside the wrench will probably break when you apply all the torque. There are no gears inside of a breaker bar.
http://members.cardomain.com/scrawnyguy18
i had to use a 1/2 inch drive and it came out like nothing.
