I just bought comp cams set of rocker arms. They;re the ones with the 1.6 lift. But when i install them i was wondering what kind of changes should i expect. I read on here somewhere that my idle will be different more so to a cam lopey sound? All help will be appreciated. Thanks
have you finished intalling them, mine just go tin today. If so how were they and did you have to modify the valve cover
I havent got them in the fire yet. But i helped a buddy put a set in his cavy a while back just dont remember what changed. And how much did you pay for your arms?
what year is your car?
I have the comp cams roller rocker set (1.6:1) in my car and I did not have to modify my valve cover.
I didn't notice any change in idle, but I did notice more top end power gain (its actually kinda fun to drive the @!#$box 2.2 pushrod now)
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/stevefiresig.jpg"></a>
i didn't have to modify anything. you absolutely should not have to modify anything with stock cam, stock pushrod length, etc etc. i noticed a BIT more top end gain... my automatic really needs to go away and i need a 5spd.
Are the crane rockers and the comp rockers fairly alike?
Also, would they be ok to use with my Mantapart sports cam?
