ok i have a 99 z24 and i just recieved my safc2 today, i was wondering if anyone has a write up on the install on this? I know how to do almost everything as far as the splicing of the sensor wires and then the intercepting the map signal, is there a 99+ pcm wiring diagram anywhere??? I have searched but found nothing, also where the hell is the pcm located, i looked for a bit today and im kinda lost, wiring really isnt my thing, im sorry for the stupidness here
bare with me though, please no bashing im just looking for info and help not insults, thanks ahead of time
I did a little search and found what you need to install the SAFC-2
Here is the post:
How to install the SAFC-2 on a 2.4
In the above post it tells you what to do and also if you keep reading someone asks what about someone with a 99 2.4 motor and they answer his question also. It's very informative.
Now in his instructions he gives a link for the PCM diagram for a 97 2.4 motor but I did a little detector work and found the actual PCM diagram for YOUR 99 2.4 motor.
PCM Diagram for a 99 2.4 Motor
Hope this helps you out. Good Luck.
thanks a ton NJ your my new hero
In all seriousness i really appreciate the help man thanks for taking a min to look things up for me, hopefully ill have this beast in tomorrow and the s/c by the weekend
boost here i come
jimmyc99z24 wrote:thanks a ton NJ your my new hero
boost here i come
It's no problem bro...that's what I'm here for. Plus I want you to get that SAFC-2 on cause I know how much you'll love it cause I love mine LOL
Good luck with boost (hopefully soon I'll be joining you)
