AC Removal - Performance Forum
AC Removal
Sunday, July 10, 2005 4:45 PM
just wondering if anyone has removed the AC on there 2.4 and has a belt just on the crank and the altanator only (removed ac and belt tensioner) thanks
Re: AC Removal
Sunday, July 10, 2005 5:11 PM
theres a couple write ups on this. for a 2.4 i think you need a a/c delete pulley and for a 2.2 you simply buy a belt for a 2.2 engine that doesnt have a a/c on it and it will bypass it.
someone correct me if im wrong
Re: AC Removal
Sunday, July 10, 2005 5:21 PM
I think if I was to put a belt from the crank pulley to the alt Pulley it might hit the timing chain bolts a lil I guess I could remove my belt and run it "like" it is on to see if it would touch but Im still interested if anyone has done it or tried different things and yeah ive seen the ac delete pulley on manta part but Im not at all about to order from them
Re: AC Removal
Sunday, July 10, 2005 7:41 PM
take off the ac compressor, you do not need a delete pulley, buy a belt that is 34inches in circumference and pull back the tensioner...put on the belt and let the tensioner go...it will work fine
Goodbye Bobby, May God grant you the peace you never found in life.
“Here's my counter-offer to your counter-offer: go f**k yourself.”
—Al Swearengen
