I just install my shift plus and I've try it and I even check my connection again to see if it was really working.
It SEEM to shift a bit quicker but it's a waste of money IMO.
another thing is that it's screwing up my tranny. when it's off, the tranny shift from 1-3.
Worst POS that I've bought for my car.
Gilles
2.3 Ho
how much power you puttin to it and what setting is it on?
LOL ok...mine works and im a newb when it comes to mechanic stuff, took out my intake box and tub, disconnected the battery and spliced in. electric taped it up, and wa-lah. mine worked. i have a feeling u connected the wrong red wire w/ the black stripe. there are two. and if u get the wrong one, then uhhh ohhh. ur so called POS works and my wheels chirp hitting 2nd and 3rd gears
its beautiful. just check ur connection man and good luck.
AkA joe m.
Ricer ELIMINATOR!
im guessing you dont have it hooked up right , ive got 2 of them and they work great
look for the post on the B&M shift plus install in the trans fourm , best pics you can get , even though the guy used the worste connectors , lol
Mfk-223 wrote:I just install my shift plus and I've try it and I even check my connection again to see if it was really working.
I have one on my 96 cavy no problems works great!!
^^^ Ditto with me too, works perfectly. no problems thus far.
i think both your english and mechanical ability are questionable
mine works fine and omg isnt a POS or screwing up my tranny
Phil Thacker
JCO North President
Event - it's the only thing I have on it so it's stock. I'll check my connection again.
As for the rest, I've try it out more today and it does shift faster but nothing to be impress. The tach needle goes down faster and you can feel a small hit when it shift from 1-2. That's on setting #2. The tire don't chirp when it's shifting but I can feel the tranny shift hard. It's just not like everyone is saying. Everybody make it look like a big thing while it's more like a tranny with really old fluid.
The tranny is shifting fine too. It's my OD that engage as soon as I get on 3rd gear.
thacks - get yourself some book about Canada and read. It's not an all ENGLISH forum so some people don't talk english as there 1st language. And for my mechanical skill, I surely know more about our cars than you do about yours.
Gilles
2.3 Ho
Btw, it was raining like hell and the tire didn't spin so it's not THAT great.
Gilles
2.3 Ho
i had a b&m shift plus that i know was hooked up right, it shifted hard but i didn't like it at all. got an autotrans interceptor and it works waaaaay better IMO
I have never heard anyone say that it will make you spin your wheels. That takes power.
i know it has improved my car for sure, cant wait to test it out at the track.
AkA joe m.
Ricer ELIMINATOR!
mine doesnt always chirp the tires , but it did knock off .2 in the 1/4 mile
It will chirp my tires into 2nd on a good patch of road. It helped me at the track also so I don't know what to tell you. It works great in my car.
It's working but not as much as I was thinking. I can slowly see the difference.
I'll have to redo my connection this week to be sure that everything is fine. urethane engine mount would help alot.
Gilles
2.3 Ho
Mfk-223 wrote:It's working but not as much as I was thinking. I can slowly see the difference.
i was thinking you might have switched that into your racecar....my bad
for an engine mount, fill the stock with urethane. did that over a year ago and still goin strong
no the Gtz is a 5spd.
I still have warranty so I would like better buying the insert for the top one. I don't care about the lower one. It would cost more to fill my mount over here than buy the insert.
Gilles
2.3 Ho
my bad, i thought you meant transmission mount.... thats the one i filled. works wonders
no one makes a mount for that yet i dont believe.
My shift-plus works great, sometimes chirps tires going into 2nd gear on setting 2.
I love it, sorry if yours doesn't have the same effect.
I don't want to jack the post but I can't find anywhere that sells the shift plus for 00-02's. Anyone wanna send me a link please?
NotlnTime
It is not made for our cars, but it can be adapted to work well on our cars. (It is made for rear wheel drive car & trucks. fyi)
MD - I know that.
Is it really bad to run it all the time at the 2nd setting??
I have a big problem if it's bad because now it's stuck on the 2nd setting. The switch is off and it's still shifting hard at redline (like setting #2) and even with the wire cut it's shifting hard. under 4000rpm it's fine but over that it's shifting hard.
So I need to know how to change it back to stock or is it really bad to run it like that?
Gilles
2.3 Ho
I would not recommend running in level 2 setting, maybe level 1.
I have driven 4 hours on the freeway with it in the level 2 setting without any bad side affects.
Make sure your plug is firmly seated in the trans....did you turn it (right or left, can not remember direction) to lock it in place?
I am assuming you disconnected the battery already.
I also hope you did not use the supplied connectors/splicers they don't ever work right.
I used the provided connectors and everything and mine works perfectly fine, no problems yet, even after 3 Autocross sessions. definetly helps me on the courses, thats for sure.
