hey i got the shift enhancer today. i noticed it says up to 98 cavaliers on 4 speed auto transmissions. i have a 2003....what gives? will this work on my car. it uses the same plug and is a 4 speed, so idk why not. and also the installation is confusing. the only guy to make a post about it on here had it for a 98 4 speed auto.
AkA joe m.
Ricer ELIMINATOR!
If it is B&M number 70380 then you are ok. The only diference in the trannys is how they bolt up to the engine.
hey thanks. i installed it and im lost in the results...it seems to shift quicker from what i have noticed. before some of the shifts the tach will go a lil into the redline before it shifts...is it supposed to go all the way into the beginning of the redline for that? and the wheels squeak a lil during shifts, i guess thats the tranny jolting?
AkA joe m.
Ricer ELIMINATOR!
I'm thinking of doing this mod as well and had 2 questions...
1. How do you change the setting? Do you have to crawl under the car to get at the tranny switch?
2. Everyone is describing the wheels chirping - is this gonna draw a lot of attention from cops?
Thanks!
Steve
http://www.bluecavcustoms.com
1. You can put the switch where ever you want. There is enough extra wire to put it in the car. Mine is under the dash.
2. I dobut it, but driving like an idot trying to make your wheels chirp might.
its not really even a chirp in an stick the tires will make a noise that sounds like a chirp where as when the auto with bm shifts its got this werid high pitch squeak noise etiher way its fun as hell.
boobs now with Riboflabin"
