so im tryin to decide what cam ot run with my hybrid,is there a certain cam any one recommends?i think im looking more towards a mid-upper range power,i emailed JBP for a a regrind and they said they have better specs then the H-272 and some customers see 11 horses from the cam alone,only downsid eis i will ahve to invest in a set of lifters
JBP specs
I/E: 230*/236@.050:.489/.489:110(105/115)
anyone think it be a good choice?
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
i wish i knew more about your setup and desired power in order to help you more.
well its a 3.1 block, with a 3400 top end thats gonna be P&P aswell as maybe a 3 angle valve job,roller rockers aswell as LS1 valve springs,underdrive pully and 62mm TB aswell as a 2.5" catback if that helps any?im not looking to run any boost on thos motor as i want a aftermarket cam and dont ahve the cash to get a turbo spec cam and all hte other componets to go with it...however if i decide to go boost id sell my hybrid and purchase stock 3400 to boost and get a regrind for that and what not
