wideband/egt - Performance Forum
wideband/egt
Monday, June 27, 2005 8:20 AM
Whats the diff between a wideband system like innovatives, or just an EGT gauge?
http://www.aplusperformance.com
http://www.modified-motorsports.com
Re: wideband/egt
Monday, June 27, 2005 9:32 AM
EGT = Exhaust Gas Temperature
Wideband A/F = Air Fuel Ratio Gauge...
The difference is in the definition, one measures the temp of the exhaust gasses, the A/F actually tells the air:fuel ratio.
Re: wideband/egt
Monday, June 27, 2005 10:16 AM
yeah what he said
egt isnt as needed as the wide band is
Re: wideband/egt
Monday, June 27, 2005 11:47 AM
i just know some people would use egt over well i guess an a/f gauge for whatever reason and I couldnt understand why.
Re: wideband/egt
Monday, June 27, 2005 12:10 PM
Wideband A/F and an A/F gauge are two very different things, I would rather have the EGT as well if I were going to use gauges as a tuning medium. Wideband is the ultimate tuning device though, next to a dyno and complete engine monitoring system.
Re: wideband/egt
Monday, June 27, 2005 12:31 PM
I plan on running both that way i know everything thats going on
Re: wideband/egt
Monday, June 27, 2005 2:11 PM
all in all would i be better off getting a wideband system or some software monitoring stuff, All in all the software could do the same thing correct, and i have a laptop already so maybe thats a better bet for me?
Re: wideband/egt
Monday, June 27, 2005 2:16 PM
high EGT + rich AFR = me shooting flames on the highway the other night
Re: wideband/egt
Monday, June 27, 2005 2:29 PM
03_CF_Blues wrote:all in all would i be better off getting a wideband system or some software monitoring stuff, All in all the software could do the same thing correct, and i have a laptop already so maybe thats a better bet for me?
Not really, the software doesn't have an EGT gauge (because there is no sensor for it), and the a/f readings are just as erradic as the narrowband gauge. The best thing to use the software for is to watch the fuel trims, which especially nice if you have a software that can map the fuel trims vs. rpm and/or speed.
Re: wideband/egt
Monday, June 27, 2005 3:59 PM
I may end up going with software and an egt gauge, the software can map that kinda stuff so overall i think that should work for me
