Im going custom 2.25 full exhaust with a hi-flow magnaflow cat. What size should I get for my 03 ecotec?
Would the 13 inch do the job ? Im also going to have a resonator.
What should it have as far as 02 sensor holes? Just one hole for OBD2? Im not going to use a sim just replace and keep the stock sensor.
Ok well I got my own little post here, this is what Im going with, anyone have a similar setup how does it sound? I already have the RK 4-2-1 Header
Cat :
MAGNAFLOW HI FLOW UNIVERSAL CONVERTER 94035
Muffler :
MagnaFlow Muffler Race 14x5x8 14851
Resonator :
289-24201
Magnum Glasspack Muffler
In/Out: 2-1/4''
Body Length: 24''
P.S. posting part numbers helps people who try to search for them
BlackEco wrote:Ok well I got my own little post here, this is what Im going with, anyone have a similar setup how does it sound? I already have the RK 4-2-1 Header
Cat :
Muffler :
Resonator :
289-24201
In/Out: 2-1/4''
Body Length: 24''
that's going to sound low-medium volume, low deep tone, non raspy, and baby a bumble bee or two when shifting at a high RPM, but other than that, the buzzing should be eliminated.
nice setup though to say the least
BlackEco wrote:
Resonator :
289-24201
In/Out: 2-1/4''
Body Length: 24''
So you used this Glasspack as your resonator? How does it sound? I have a Pacesetter 4-1 to a High Flow Cat (94035) to tubing and a muffler. But it is way to loud sounds like a weedwhacker on crack. I was wanting to put in a resonator but they are $60+ Then I see this and I can get that Glasspack from Summit for $20. Let me know if it has a real deep tone to it or if it is loud and Briggs & Stratton like.
Heather wrote:BlackEco wrote:
Resonator :
289-24201
In/Out: 2-1/4''
Body Length: 24''
a glasspack is a resonator...
all a resonator is, is a smaller muffler..... all a glasspack is, is a resonator filled mainly with fiber
glass hence the name
glasspack
find the largest one you can and preferably without louvers in it... if you look in and it looks like a cheese grater.....pass.
if its just smooth with holes, get.
sounds identical to mine almost, all ordered up, hopefully get it on asap
Cat :
MAGNAFLOW HI FLOW CAT 94035
Muffler :
Dual Magnaflow Mufflers 14833, each has dual square tips for my type J rear.
Resonator :
289-24201
In/Out: 2-1/4''
Body Length: 24''
Then going with a ceramic coated pace setter header, I cant wait!
http://www.aplusperformance.com
http://www.modified-motorsports.com
wont you throw a CEL code on the ecotec if you dont have an OBD compliant cat, with 2 fittings for the o2 sensor, b/c that's what the stock cat has
ODB compliant cat? never heard of that one.
anyways, you wont have a CEL if its installed right. some cats are directional and if put in the wrong way you will have a CEL
yeah, flowmaster makes them, and i think a couple other companies, but the flowmasters start at 200 bucks, and thats alot for a cat..........i've talked with a few people and they've told me if you dont keep the stock cat with the eco, or get an OBDII compliant one, then you're going to throw a CEL
well, when i looked the cat he's getting is OBDII compliant but it's only got one sensor fitting, and i was under the impression that the ecotec had 2 fittings on the cat
What do you guys think about the catco converters?
What do you guys think of the catco converters?
yeah i could be wrong about the 2 sensors.....i talked to a guy over on aleromod.com and he seemed to think there was 2, so im not sure
Paul Tjepkes wrote:What do you guys think of the catco converters?
Carsound (Magnaflow) > Catco
shouldnt only be one sensor on the cat of a jbody. 94035 already covers the sensor and complaiancy.
pretty much most all that are made now frm big companies are obd complaint
I think its only one sensor, if its two all you have to do is drill a hole and order the bung to insert the other sensor (this is actually sold by magnaflow)
Everything is arriving in a day or so, and a guy in my club might help me get it installed, I have to get all the pipes custom made and welded. When Im finished I will post a video from different angles of the sound.
I ended up ordering the Dynomax from NAPA auto parts, 33 bucks, they ordered a 25 inch one, and had it in a day. So if you want one quick that may be an option for some people as NAPA is a dynomax dealer.
BlackEco wrote:Im thinking the magnaflow 94035
http://www.car-sound.com/catalog/universal/940.aspx
bingo!
Land Pirates sail the open roads
DISCLAIMER: If anything I say offends you, I don't care..wear a helmet. Also, the information
I post is what I know to the best of my knowledge. If I am wrong, please correct me so that
others as well as myself may learn.
Premium sinc 6-17-04
also check www.justmagnaflow.com for the cat.
i paid $67.51 US for it shipped to my door
I ended up going with the 91035 cause the 94035s were backordered, either way, hopefully have it on in the next couple of weeks.
How much time should it take to install a header/bend pipe, and get it all hung/welded up, also its being split to duals. Just gettin an idea so they dont screw me on prices for labor
alero_ecotec wrote:yeah i could be wrong about the 2 sensors.....i talked to a guy over on aleromod.com and he seemed to think there was 2, so im not sure
there are 2 sensors in the obdII system but one is pre-cat on the exhaust manifold and one is post cat...
watching this as i'm looking to upgrade my exhaust with a high flow as well (in addition to a header, new muffler, and new piping)
