stock engine Mounts common problems? - Performance Forum
Saturday, June 25, 2005 3:11 PM
Hey guys I got 01 cavalier auto 4spd, I am just wondering if those cavaliers have alot of problems with engine mounts and tranny mounts, I notice with my cav I got a some play with the engine at idle little engine shake, only got 118,000k on the engine, Tune-up / fuel filter has been done, Oil changed, throttle body has been cleaned, IAC has been cleaned out as well. Just wondering if people had the same kind of deal as well?.
Thanks guys.
Re: stock engine Mounts common problems?
Saturday, June 25, 2005 10:19 PM
The 03 cavy I'm driving around likes to shake in its mount when I'm driving in "gas-conscious" mode. 5th gear at 35-40 mph and I hit a bump... good lord the whole car shakes if I'm on the gas
There are aftermarket motor mount bushings you can purchase that will alleviate this problem (but instead of allowing the motor to vibrate in the mounts, it gets transferred to the chassis)
Saturday, June 25, 2005 11:22 PM
Just buy the solid lower dogbone mount and upper mount insert, as well as the bushings for your tranny mounts from Karo at CarCustoms.net and you'll notice a difference in torque.
Saturday, June 25, 2005 11:30 PM
tranny mounts might be good for Mitch Davis, but rich weeks has a 4 speed auto.. and tranny mounts are not yet for that.
and yes the mounts will transfer the vibes into the car. but they will eventually go away. i hardly notice mine anymore
Saturday, June 25, 2005 11:32 PM
99redz24 wrote:and yes the mounts will transfer the vibes into the car. but they will eventually go away. i hardly notice mine anymore
that's either you've worn out the bushings on the low mount, or you are just used to it. it's far "worse" on the automatics (like mine) than it is with a 5spd.
Sunday, June 26, 2005 8:05 AM
Or you can use a "cheap" way, use a torque dampener.
All it is, is a solid piece of tubing connecting your engine to either the fire wall, or a structual piece, like the front cross supports.
You can use piping, straps, flat bar etc...
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Sunday, June 26, 2005 10:25 AM
Lawnmowerracer wrote:Or you can use a "cheap" way, use a torque dampener.
if it works it works but i am not going to necessarily recommend that to anyone.
Sunday, June 26, 2005 11:03 AM
Hey guys thanks for the reply's, I checked with the local auto parts shop they got the poly upper and lower mounts & tranny mount as well for the 01 cavalier, Before I spend some cash at them, I am gonna get into my friends shop and use his hoist to see whats going on under neath on those mounts.
Thanks again guys.
