DIS-2 on Ecotec - FINAL, complete diagram - Performance Forum
Wednesday, June 22, 2005 1:54 PM
I know this is a semi-repost from my thread in the nitrous forum, but I felt it was more relevant here, and I hope all of you waiting for information on this mod will understand. This is also a final, edited diagram which i havent posted anywhere else, certified by me myself, who successfully installed my DIS-2 plus (62112) on my 05 sunfire, with an external coil and plug wire conversion. Car is running great. This is what you need, with part numbers:
-msd dis-2 (62112) or the programmable version (62152)
-msd blaster coils x2 (8224)
-msd cam sync generator (8914)
-msd super conductor plug wires (31159)
-msd coil interface module x2 (8870)
To remove the ICM from the coils, youll need a Torx t15 screwdriver. Also, for my install, I completely removed the stock coils and housing (the black "Ecotec" plate).
The pins on the bottom of the ICM (which you can see once you pull off the female-female connector) look something like this: (* * * *). Trigger 1 wire (white) goes to the pin on the far left, and trigger 2 wire (green) goes to the third pin from the left. No connection is necessarry to the far right lone pin, as well as the second pin from the left.
To connect the trigger wires to the "inter-connect" plug on the ICM, I put solder on the tips of the wires so they were like pins, pulled out the female to female connector from the ICM, stuck the solder-tipped wires in the corresponding connector holes, and plugged it back into the ICM, and taped it all up.
Any questions, feel free to email me.
Re: DIS-2 on Ecotec - FINAL, complete diagram
Wednesday, June 22, 2005 1:57 PM
still wrong you get the ignition voltage from the middle pin on the icm output and before the coils input
Wednesday, June 22, 2005 2:02 PM
oops, forgot to add: I mounted one coil pack on the drivers side strut tower, the other right behind the battery, and the dis-2 and cam sync generator in the driver's side fender well (accessible if you remove the drivers side headlight).
Also, for cleanliness, ease, and good looks (they go nicely with the red plug wires), I bought from Jeg's a set of black plug wire dividers. The part number is 720-9728. They're great for looks and keeping your plug wires separate and organized.
Wednesday, June 22, 2005 2:09 PM
must be working fine
TURBO KIT...$4,000
RUNNING 20 PSI...ANOTHER $2,000
SMOKING THE TIRES ON A 3RD GEAR ROLL...PRICELESS
Wednesday, June 22, 2005 2:13 PM
you dont need to get it from the pin. i checked with a multimeter, and the pin provides a constant 12v DC. The pink wire also provides a constant 12v DC. For ease of wiring, i used the pink wire. There's no difference.
Thursday, June 23, 2005 11:18 AM
what all do you gain from this one?
whats the diff between this and the programmable one?
http://www.aplusperformance.com
http://www.modified-motorsports.com
Thursday, June 23, 2005 12:30 PM
So how much of a noticable diffrence from stock, and where you notice the diffrence?
Beware the Rouge Dragon.
Thursday, June 23, 2005 12:32 PM
smoother idle below 3000rpm, increased power above 3000 to red, better gas mileage most importantly
Thursday, June 23, 2005 12:50 PM
and how much did all those parts run total?
Thursday, June 23, 2005 3:50 PM
Parts Total: $643.16
03_CF_Blues wrote:what all do you gain from this one?
Gains included throttle response, overall power and fuel economy gains (id say somewhere in the range of 5 hp according to butt dyno).
Thursday, June 23, 2005 4:26 PM
so has anyone taken actual pics of their set up yet ???
you gotta remember we LOVE PICS
lol
Thursday, June 23, 2005 9:38 PM
so $600 for 5 hp gain and better throttle response?
Thursday, June 23, 2005 9:44 PM
NJs Honda Killa wrote:so $600 for 5 hp gain and better throttle response?
and in the future really nice ignition tuning capabilities
Thursday, June 23, 2005 9:47 PM
don't forget with this mod you can put msd stickers on your car and not be called a poser.
i think the big advantange will be once other power adders are installed--like nitrous or a turbo.
-DS
"I'm a product, of my environment
So don't blame me, I just work here
But I wanna f*** it up"
Offspring - americana
Thursday, June 23, 2005 9:48 PM
I have a website that is very close to completion which I'm sure will be the most comprehensive how to thats been seen in a long time, just give me about 2 more days and there will be a posting on it
Friday, June 24, 2005 5:36 AM
keep in mind all that starts to multiply the more parts you add to it that adds air and fuel. you;ll already have more spark, when more fuel and air comes, bigger explosion
Friday, June 24, 2005 6:15 AM
Hook up the launch RPM control feature and that alone can be worth several hundred dollars when you start "gating" people (cutting a good light) at the track.
Connect it with a toggle and a nitrous style WOT micro switch on the clutch pedal.
It allows total focus on the tree with a five speed car, and a nice feature with an automatic, even without a trans brake.
Friday, June 24, 2005 3:14 PM
i have the programmable dis 2 and it retartds my ignition when i go into boost so yeah i didnt pay $600 for the whole setup but if i did it would be well worth it to save my $$$$.$$ build up
