Draining the Tank - Performance Forum
Draining the Tank
Wednesday, May 11, 2005 8:00 PM
Whats the best way of doing it?
Re: Draining the Tank
Wednesday, May 11, 2005 8:02 PM
Use a siphon pump.
Wednesday, May 11, 2005 8:05 PM
Is there a screen in the filler tank? If thats even the way to do it?
Thursday, May 12, 2005 10:43 AM
not sure about the years of the screen. you could probably pop off the hose clamp on the tank to the filler neck and pump away...
or if your changing your tired pump (if it still works) you could take off the fuel filter and run a tube from the line to a fuel can and jump the pump wires with a 12v source like a battery or run the KOEF a few hundred times.
the wiring harness under the back seat goes like this
grey__pump +
black__pump -
purple__fuel level +
black / white__fuel level -
grey / black__?
green__?
orange / black__?
one of these fellas is the +, one is - , one is 5v reference for the tank pressure / evap system, i forget which is which, but a dvom will tell you
___________________________________________
red
black
twisted together__ABS
brown
white
hope this helps.
CAR GODS MADE THE 1.6 SOHC TO MAKE US 2.2 OHV GUYS FEEL BETTER.
Thursday, May 12, 2005 2:19 PM
I couldnt siphon mine so i just unhooked my fuel line under the hood and hooked a water hose to it. Then just turned the key off and on (primeing it) til it was empty.
Didnt take TO Long.......
Thursday, May 12, 2005 3:42 PM
red96sunfire1022 (The Fat One) wrote:I couldnt siphon mine so i just unhooked my fuel line under the hood and hooked a water hose to it. Then just turned the key off and on (primeing it) til it was empty.
that is one way to do it i suppose. i suppose that leaves a better aftertaste than gasoline.
Thursday, May 12, 2005 6:20 PM
Thursday, May 12, 2005 11:05 PM
the old siphon by mouth through hose attempt...
