by the way I know its spelled ecotec but I figured if I added the H someone would come just to complain and then read this and might have somethign to say
Ok I've read thing saying it does work I've read things saying it doesn't. I don't want a big ass goofy looking tach that looks more like a dinner plate then a gauge, I just want to hook up a shift light. So whats the deal with the tach adapters?? Also I just need an RPM signal, and the crap that comes with the light correct?
Thanks <br>
Use this,
MSD Distributorless Tach Driver
MSD brand
Distibutorless Tach Driver
Part # 8913
That is what i'm using with my Ractive Tach, so I can't see why you couldn't use it..........
<br>
^^^ dude you just plug it in and it worked right? didn't have to mofify it at all? <br>
I just hooked up my SDS EIC and was told by the former ecotec turbo owner that, The wire you must splice into for RPM reading is the ORANGE wire.
Its all hooked up but I don't have the injectors welded in yet, so I don't know if it really works.
Any Help???
<br>
Double Checked, Should be the ORANGE wire!
<br>
so we there are 2 ways to make a work? I'm guessing one of the ways wont work.... <br>
so its either red, orange, or pink...... <br>
lol uh oh...
my tach was hooked to the white wire, LMAO!!!
I had an apexi tack which could read down to 1 cylinder so I didnt need any fancy adaptors <br>
LE61T PTE6262 Powered
the red wires reffer to the wiring built into the tach driver....
the pink wire is the one i reffered to in my post up there
<img src="http://webpages.charter.net/cody350/msd8913.jpg">
STRAIGHT FROM THE MANUAL ON MSD'S SITE!
<br>
Evil Major wrote:get a sunfire cluster
what the hell do those sunfy clusters have that the cavs dont?!?! lol
<br>
actually you really dont have to have a tach adapter if you dont mind your tach only reading half your RPM'S..as for the wire you can use just about any of them and get a signal...if half rps isnt important just set your shiftlite to come on at about 2,700 or 2,800 rmp's and that should really be about 5 and a quarter or 6k rpm's
ill just call phil if i want one installed lol <br>
Well, I tapped the pink wire (per MSD's instructions), but there are I think 2 wires in the custer that work so.........
Darkstars: Yeah just wired it in and then wired up the tach, easy as ckae or pie, whichever you like........
<br>
^^^ cherry cheese cake! <br>
i know, bringing back a dead post, but i had a question. stand alone shift lights that are RPM controlled still have to have a tach adapter to work on a j, right? (curses under his breath).
<a href=http://jbnw.org><img src=http://home.comcast.net/~fitzgerald.d/RR4.bmp>
Why do you need this? You were parting out your car. Again, you fail at unmodding.
By the way... it's Ecotec
this is an old post, rather than start a new one and have them link me to this post, i just re opened it. now, the question is, do i have to have an adapter regardless of the tach or lite i use to tap into the orange wire shown here?
basically the reason being that when you tap into one rpm on one of the TWO coils you'll only get half an rpm signal
i GUESS you could run a shift light off half rpms but i'm not sure how well it would work
and i wouldn't say it's a "j" thing... more an ecotec thing (as far as i know)
and yes, this post is old.... ryan is still being all womanish about his car and modding it or unmodding it...
actually, that will work, the shift light goes up to over 12k rpms, so, therefore, all i gotta do is set the shift light close to max, and the sucker will light up at 6k when i want to shift
thanks all!
Redrocket wrote:actually, that will work, the shift light goes up to over 12k rpms, so, therefore, all i gotta do is set the shift light close to max, and the sucker will light up at 6k when i want to shift
thanks all!
no, because you'll be reading HALF of your actual rpms, meaning you need the light to come on at like 3200 rpms lol
