Ok, heres a list of whats still available of anybody is interested. Al prices are OBO also.
Spyder Automotive Dual Snorkel Ram air hood painted red in great shape-------350 obo
X1 SLR style fiberglass fenders painted red and in decent shape-----75 obo
Erebuni SLR Style Power Folding Mirriors(power glass not power folding) Brand new never installed-----200 obo I can also get some plates made to correct the mounting angle of the mirriors, for 150 bucks.
Sunfire Guage cluster 99 model with digitial odometer and is for a manual trans----75 obo
Complete 95-02 Sunfire Dash charcoal and in great shape, includes the steel tubular support that goes behind it in case you want to swap in into a cavy.-----200 obo
95-99 Sunfire Coupe Center Console for a 5 speed, has a brand new black leather boot and is charcoal in color, has a few small cracks in the bottom of the storage section where it bolts to the floor, otherwise in great shape, also has a couple dings in the arm rest lid.-------50 obo
Bear 13" front disk conversion, complete kit minus thebraided brake lines, i could not find my stock rubber lines so the braided ones had to stay on the car. In great shape and will make your cavy stop on a dime and give yo change back. Rotors are the eradispeed cross drilled and slotted and zinc washed, calipers are painted red. Somewhere in the neiborhood of 15K miles on everything.-------750 obo
Fondmetal white 6700 series wheels and tires, 18x7 on the wheels with a 50mm offset and 225/40ZR18 Yoko ES100 tires. They fit my car just fine and never rubbed at all not even at full lock. wheels are straight and true, but do have some minor nicks and scratches, some of which were there when i bought them. 3 of the tires are like brand new and in excellent shape, and the 4th has some irregualar wear on the outside edge, i bought it used so i think the wear started on the previous car.-----500 obo
RK Sport Tubular lower control arms. In excellent shape no cracking and they made the car hanle very nice and tight and i never had any sway bars. They are red and have brand new Moog ball joints installed whrn i put them on the car about 15K miles ago or so. They are in perfect shape.-----225 obo
2K-02 Clear corners with white superbrightleds.com Led bulbs in them, they look like a bluish color at night and woudl match up with some HIDS and look killer,i necer had any issudes with the white. in excelent shape, pnly been on the car for a few months. I bought the corners fromn a-plus and the bulbs online.------45 obo
95-97 SI Stainless Steel Valves 1mm OS and brand new in the plastic like i got them from SI. Was for my turbo engine build that is no longer goign to happen. I paid just over 100 bucks shipped for them and would like to just recoupe my cost.------100 obo
Mitsubishi TDO6 16G Turbo, can support up to 400 crank HP and is a perfect turbo for a 2.2-2.5L 4 cylinder. Brand new and has the turbine housing ceramic coated and the comp housing has been polished.-----400 obo
Exploited Equal Length turbo header for a 2.2L/22200. Very nice looking piece, i did have to cut off the external wategate hookup as it need to be reloacted, and it wil need to be rewelded back on, in ots old spot it hit the thermostat housing on the 2200. Setup for a T3 turbo, and with this header the Mitsu turbo fit very nicely down low and against the block. Includes two 2200 1/2 thick flanges to be used as spacers so the turbo has the clearence needed to even bolt up, just use the factory stel manifold gasket(three of them) and you will never blow any of the gaskets. This is a one is a one of a inf piece, Brian only made one, and when the guy that is was made for got it it would fit the block but it was too close to the block and the turbo woudl nt bolt up, i then bought it and got the 2 flanges for spacers and it works like a champ and looks killer when installed. If you buy the turbo ill throw in the beginning of the downpipe and this header for another 100 bucks. Or the headers and spacers by itself.-------200 obo
Stock 2002 2200 with only 3K miles on it, mostly complete and has been torn down for inspection and to get it ready to rebuild.--------150 obo
FDP 62mm 2200 Throttle Body, this is also a one of a kind piece made by FDP, that was the prototype for the 2200 engine, and im not sure whay happen and why they were never produced. This is made out of Billet Aluminun and has all the needed vacumn ports and has the correct throttle cable hookups for auto trans and cruise control. Will not include the IAC or TPS sensor, you can use the ones off your stock TB just fine. Very little milage on it and in great shape, you wont be disappoinited.-----100 obo.
Custom Homemade cold air intake, worked very well, just not the prettiest thing to look at. MIght want to get a new filter for it.------50 obo
I guess thats all i can think of right now. I will include UPS ground shipping on all of the smaller stuff that can be shipped easily, but on the larger items i woud prefer a local sale, of atleast if your local to the Austin, San anotnip or DFW area and if course Hosuton im willing to meet you somewhere to make the exchange.
Thanks
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
That pretty much says it all.
Support the site that supports your habit, Go Premium.
