yeah i havnt changed it since i got the car
clean your throttle body, your TPS might be going out also, might wanna change the fuel filter
i had something similar happen to my truck and it was a sensor that went out. it would hardly start and when it did would rev high before it would switch gears(auto). other times id give it gas and it would die or vibrate. i ended up putting it in a low gear and took it to the shop.
One of the girls done her came to me with the same kind of problem on her 2002 cavalier and it came to be that the fuel pump was bad. Her car would drag through gears and several times when she would turn it wouldjust shut off.
Ecoclean wrote:hey so what about the guys located out of dfw? I have noticed that the crew here in SA has really began to grow and I like most of what you said so I might have to inforce those here to.
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
You would like those pink stickers!
just me and JD tonight in bulerson?
hey by the way where is the fuel filter i cant seem to filnd it
NO LOVE FOR THE SOUTH SIDE????? Well paul is comming after he get's off, I'm not sure if Amanda's comming out to pic up her spring's or if we're even going to put them on tomm, Kelly has to work,haven't heard from anybody else.
fuel filter is located at the back of the car in front of the trunk area. its a silver cylinder looking thing.
shape of an OE filter will depend on the year of your car. location is pretty much the same for all years i've toyed with, though. as clever one noted, it's under the back of the car between the beam axle and the fuel tank. some early 3rd gens had square filters from the factory. usually cylindrical in shape, though.
most cars i've seen at a single meet was 20. that was, i think, in '02 at Texas Motorplex in Ennis.
Have you seen the turbo wagon?
14.069 @ 98.91mph
229.1hp & 261.7ft/lbs @ 6psi
no tuning time
I just got my tails but they arent threaded like my stockers are amm i going to have to thread them myself or get some special nuts/bolts to hold these bad boys on?
what is the orange wire that runs under my back seat??
dont know????
i figured out the tails but i think i need some rubber for the outter housing because there is a gapat the bottom can anyone give me an idea?
My tails aren't threaded either. I believe the speednuts are self-threading. ???
I also think you have to use the foam off the stock tails or live w/ the gap. I'll let you know more tomorrow. Projectors,black corners and tails go on my car first thing in the morning.
I'll see you all on Sunday.
My Cardomain Page
Vash1275 wrote:what is the orange wire that runs under my back seat??
It's been awhile but I think it's for your rear defroster.
Billy,Get ER' Done!!!!
Yeah thats what i found out last night on aol aim that the screws that are on the stockers should thread the newer ones. Hey billy did yours come with the rubber piece that goes on the outter light housing???
when im decelerating i hear a high pitched whistle comming from it, i think, i cant really hear it i higher speeds but slowing down from about 40mph i can hear it all the way till i stop. keep in mind i dont have to hit the breaks to hear it. any ideas why or where it is comming from?
hey so whats going on tonite. are we putting amandas springs on? starbucks??? some body call me and let me know.
