Up for sale is my 02 Cavalier. On pump gas it makes 548whp/493wtq, engine only has 15,000kms on it and has only seen 3,000 of them while turbo'd.
Engine:
9:1 .020 Overbore Wiseco Pistons
Eagle Rods
Clevite 77 Rod And Main Bearings
2.3 Oil Pump Swap With Modded Oil Pan
Ported And Polished Head
1mm Oversized Valves
Bronze Guides
2.3 HO Valve Springs And Retainers
2.4 Keepers
2.3 W41 Cams Modded For A 2.4
2.4 Intake Cam Tower Modded For 2.3 W41 Cam
2.3 HO Intake Manifold
RSM 62mm Throttle Body
Camaro IAT Screw In Sensor
FTS Turbo Header Ceramic coated
Garrett GT35R .82 A/R hotside & gt3076 style compressor side
44mm Tial Wastegate
1 7/8 Wastegate Dump
3inch Turbo Back Exhaust To An Apexi WS Turbo Muffler
2.5 Bead Rolled And Powdercoated Charge Pipes
Greddy Intercooler 27.5 Long x 11 Tall x 3 Thick Core
HKS SSQV Bov
Autometer Fuel Pressure Gauge
Venom Fuel Rail
Injector Dynamics 1000cc High Imp Injectors
Aluminum Crank Pulley From Apex Modified
RK Sport Upper Engine Mount Insert
RK Sport Lower Engine Mount
Spec Aluminum Flywheel
Bully Stage 4 clutch
Team Green LSD
Team Green MSD Coil Pack Mod
Turbosmart Single Stage Electronic Boost Controller
Racetronix intank fuel pump with bosch 044 external fuel pump and - 8 feed line
Suspension/Wheels/Brakes:
RK Sport Pro-Street Coilovers
Eibach Front And Rear Sway Bar Kit
Ractive Polished Front Strut Tower Bar
RK Sport Rear Strut Tower Bar
18" Axis Reverbs In Gloss Black
225/40 18" Nitto Invo tires
Baer Big Brake Kit Front And Rear
Interior:
Painted Dash To Match Exterior
Scat Black Sport seats
B&M Short Shifter
05+ Mustang GT Shift Knob
Silver Shift Boot & E-Brake Boot
Lotek Triple Gauge Pillar
30psi Autometer Ultra Lite Boost gauge
100psi Autometer Ultra Lite Oil Pressure Gauge
Innovate XD-16 Wideband
New JVC blue tooth/ipod ready deck
Exterior:
RK Sport Carbon Fiber Extractor Hood
Blacked Out Headlights/Corners
95-99 Toyota Cavalier Taillights
Toyota Cavalier Trunk Liner
GTHID 6000k Hid Headlight Conversion
Wings West W type front lip
Miscellaneous:
Compustar Alarm/Car starter With Pager
Tinted windows:
5% rear
6" Silver Vinyl Strip On Windshield
Carbon Fiber Coolant Tank Cover
Carbon Fiber Battery Cover
Carbon Fiber Brake Fluid Tank Cover
Carbon Fiber Radiator Cover
Carbon Fiber Fuse Box Cover
Powder Coated IDI Cover Black And Polished The Lettering
MRZ Performance Billet Aluminum With Carbon Fiber Center Strut Tower Covers
*just put in new tie rod ends/front wheel bearings/ball joints on both sides, tires are pretty much brand new and turbo setup has 3000'ish kms on it. Tuned with hp tuners on pump gas with no issues. Great little car but cant justify having 3 vehicles now. Car is loan/lien free
