will the gm strut bars off the verts fit on the eco.  say from like a 97  vert?
thanks guys
Don't see why not... the strut tops are the same.
you know i wana say that there is a diff between years. but im thinking its for the rear strut, the front should be fine
The only thing that changed was the strut mount... but the metal frame part is the same
Coming from the guy with an Eco, I'll back that answer
hey james, do you know if the rear is the same for all years
not sure, I do know that the rear strut mounts have the same bolt combo, so essentially they are the same, and ive transferred rear strut bars from my 03 to a 95 cav before, and from a 02 sunfire to a 04 cavi before but they weren't GM strut bars. I wa sunder the impression Gm didn't make rear stut bars though, jsut front ones for the verts.
But I know that all aftermarket bars, regardless of who makes them have the same bolt hole pattern for all J-bodies years 95-05, so you could order a bar made 95-99 on ebay and it would fit your 95-05 cavi or sunfire.
^^Ding, ding, ding.  We have a winner
sweet, thats what i'm gonna do then, just order a set off ebay
Glad to help!
adn btw, cody ar eyou registered on JBNW.org yet, if you arent get r done!
the gm strut bar will fit, however you have to modify the ecu bracket and the cruise bracket (if equipted) to allow the bar to fit properly. its not too hard, i have one on mine
