My check engine light has been on and I went to get emissions tested today, and it failed with a "P0140- O2 Sensor Circuit Activity Detected Bank 1 Sensor 2." Which O2 sensor do I need to replace? BTW I have an O2 simulator, could that be part of the probblem? Its a 96 2.2 5spd.
\thanks
96 2.2 5spd 16.68@86.3 with the rims....A work in progress
http://www.cardomain.com/id/96cavcustom
Sensor 2 is the Catalyst Montitering Sensor ( the one that is supposed to be where the sim is at). Do you have a cat? If you still have a cat, that mod is pointless. Put the O2 sensor back. If no cat, check to make sure the sim is hooked up right.
O.K. so just hook that wire back up to the sensor then? (remove the sim)
Where at are you from in STL, I'm in south county
Oh. I see you are already on there, but you haven't been on in a long time.
