Wel recently I have been having a problem with my drivers side turn signal. the back no longer works (the light works fine it just doenst blink) but the front blinks crazy fast now like almost double time. Also the indicator on the dash is blinking and making the clicking noise twice as fast as it does when I go to make a right turn.( meaning that the right turn signal works fine and is still perfectly normal.) Anyone got any suggestion of ideas? Thanks in advance.
Rich
isnt that a recall? take it to ur dealership it should be under warrenty anyway.
MY 2003 SUNFIRE 15.6@86mph
~1QWKZ24
www.streetracing.org, 08/2001
im having the same problem, any solutions??? what bulb to change??
anyone have any suggestions??
Okay first off it blinks twice as fast because there is less resistance in the back, less resistance = more current flow, to decrease resistance its the exact oppisite add some sort of resistance, like a light bulb.
Anyways you said the light works so it just doesnt blink. Well the light works, so we know the fuse is good, we also know you have a complete circuit, so you have power and ground, also by it working we know the contacts are good.
See the blinkers usually operate by the switch, opening and closing, open and closing, completeing the circuit, then breaking it, then connecting again. So I would test the switch, let me know what you find out.
Rob S If his front right turn signal is working, the dash indicator is working, but the rear is not flashing, iIT IS NOT THE SWITCH. The bulb could be a two element bulb and the one for the turn signal is burned out. If the switch was bad, no turn signals would work.
rich 222 Try replacing the rear bulb and see if that fixes your problem.
98 Z24
RIP Specks
i replaced my rear turn signal bulb and problem was solved
What I don't understand is you guys come up with the most complicated things to check for. Why not start simple first and THEN work to the complicated stuff? There were many answers thrown around, most of them wrong with the symptoms he was describing. Heck I'm not suprised someone didn't say check your antifreeze level or something like that.
http://www.cardomain.com/id/lanman31337
Sponsored by:
JLCaudio.net
the bulb change will work for now but wont last....change the socket....pick 1 up at your junk yards.
had to do this to my 2004 sunfire....had the same problum, changed the bulb, ahundreds of time....then whent and changed the socket and every thangs ok....
LANMAN I agree with you on this one. That is why I suggest to replace the bulb first. The simple things is what I always suggest first.
98 Z24
RIP Specks
Mine did that, bulb was out, bought a new one for 2 bucks, and it's worked fine every since
