First what the heck are they called? The 5 bolts that your wheel is held in place by, and the lugnuts keep the rim on. I snapped one damn near in half when taking off a lugnut, and now im running with 4 bolts for about a day now.
Where can i go to get a replacement bolt, and anyone have a quick description on how to replace it? Is it just the bolt i need or the entire thing that holds the rim on? Comments are appreciated.
Wisdom comes at the cost of sanity - A.B.
ok, here goes, if you have LUG nuts, right? You still with me? And you have bolts that those LUGS go onto, get this... its the best part! Maybe, and I mean maybe, cause I could be wrong here, someone correct me if I am! Could they be called LUG bolts? HAHAHAHA!!! I'm just bustin on ya man, no hard feelins I hope. Anyway, you can get them at Autozone. What you are goin to have to do is also get a T55 torx bit, so you can get the hub off, the LUG bolts are spleens from the back of the hub. I suppose you could just take a hammer and bang it out of the hub, you might need a punch tool if it broke real close to the hub. Cost ya about a buck and about 4 for the T55 Torx bit. Oh and by the way, I ran for a year on 4 bolts on the front primary drive wheel of my cav and never had a problem
So if you aren't too sure about it, I wouldn't rush into doing it.
Scott
If ya didnt give me a good answer i'd rag on ya, but since you gave me the information i needed, ill just say thanks.
Only one of my rims has all 5 lug bolts... the rest have 4... do I win a prize?
Girls suck, buy a fast car.
actually there called wheel studs u retard dont make fun of him when you dont even know what there called.
-Borsty
.... that was a definate own...
There is no need to remove the hub when changing the stud. Just bang it out with a hammer.
