Hello All,
the car is a 98 Z24.
problem is when in idle / traffic the fan does not come on at the correct temp and the car begins to overheat.
Its fine when driving
What I have done...
thermostat replaced 1 year ago w/ water pump
replaced fan relay
replaced coolant temp sensor
The fan turns on fine then A/C is active.
I'm stumped..is it a computer problem??
I thank you all for any input you can provide!
Thanx!
- - - mo
What temp does it come on at?
98 Z24
RIP Specks
I'm from canada so its in celsius....I convert it to be around 220deg F.
That sounds about right for when the fan should turn on. If you want to, you could do the override mod. This puts a toggle switch in line with the power wire for the fan. What this enables you to do is manually turn the fan on when you want to. I would say that your current fan is working properly. I'm sure the temp starts to drop when the fan comes on, Right? If so, I wouldn't worry. So long as you don't go into the red you should be fine.
98 Z24
RIP Specks
the fan comes on at the 3/4 mark on the gauge
which is around 220 and normal
