...So since thats happened my car has smelled like pure ass inside, anyone have any suggestions on how to clean it. fabreez doesnt help much..
my magnaflow decal gives me 100 hp!
Remove seats
Remove carpet
Alow everything to air dry for several hours
If really wet, use a shampooer or wet-vac to extract moisture
THEN spray FeBreeze (don't overdue it) as you reinstall everything
-Ferrite
I had this happen almost every day, Cheverolet sucks at making convertible weather stripping. The smell goes away, I just had the option on putting the top down and air it out.
How many steps to heaven, Doc?
...Ah, metaphysics.
Also spraying wd40 onto the body under the carpet is a good idea. Helps to prevent you floor from rusting out.
Getting the inside of you car hot with an old hair dryer will speed the process. You just have to open the doors once in a while to let out the hot moist air.
you can put some coffee into a half pound plastic container from a deli and poke some holes in the lid. it works great.
happened to my car, i left my passenger window half down and it poured one night. the arm rest and half the seat were soaked. just got a hair dryer and dried it. took a while but it worked
Shawn wrote:you can put some coffee into a half pound plastic container from a deli and poke some holes in the lid. it works great.
Then when you make the coffee it will smell like ass. Seriously, I did this with my S-10 and I just aired it out and the smell eventually went away.
God bless America.
