How do I find a short w/ a voltmeter ?? - Maintenance and Repair Forum
Thursday, August 25, 2005 10:55 PM
I bought a voltmeter to find out whats causing my battery to drain. I don't even have the slightest clue on how to use it. Please help me figure it out.
Re: How do I find a short w/ a voltmeter ??
Thursday, August 25, 2005 10:59 PM
i believe its just putting + to + and - to - there should be no current when the key an everything else is off
The one, the only, ME.
Thursday, August 25, 2005 11:08 PM
no current if the wire is shorted correct??
Friday, August 26, 2005 5:57 AM
Hi Arsonist
I have given you some info on the other post.
I presume you mean a multimeter and this link gives a few ideas. If you have any more questions post them up and I'm sure they will be answered
http://www.boatsafe.com/nauticalknowhow/electricity2.htm
Good Luck
Alont
Friday, August 26, 2005 11:33 AM
WARNING: do not use the ohlm setting on a live wire. You will toast your multimeter or even your hands.
Disconnect you battery and drain the system (turn your lights on) before using the ohlm setting.
Then I would recommend useing the ohlm setting and touching the black to the body of the car (unpainted surface, aka a bolt or the block) and touching the red to the tops of the fuses. If you get a low reading (something under 1k), you have a problem.
Saturday, August 27, 2005 8:04 AM
If there is a short wouldn't it show infinite resistence?
