ok this isnt on a j body, but its braking systems so its all the same
im driving around a 96 regal, brakes are warped. im driving it around and if i dont do above 40 mph. the pedal is fine 45 mph or move, the pedal sinks to the floor like a line broke. this is very odd.
i cant find a leak, fuild is full......... im out of ideas.
any suggestions?
-Borsty
check the rear wheel cylinders. it nothing then flush the system with fresh brake fluid. it that does nothing time for a master cylinder.
see ya!
its 4 wheel discs, no wheel cylinders homie.
-Borsty
i could just set the car on fire, then everyones happy.
-Borsty
if i lose all brakes i could flintstone it and shove my feet thru the floorboards.
-Borsty
um, what novaracer didn't say specifically... there might be an "internal leak" @ the master cylinder...
that or check the booster/ check valve
you are having heat probs the fluid is boiling making small air bubbles
VOTE FOR PEDRO!!
is your rotors to thin if so that they cant get rid of the heat fast enuff so its going in to the calipers and making the fluid hot
VOTE FOR PEDRO!!
also its called brake fade
VOTE FOR PEDRO!!
