99 Z24 DRL Relay Location - Maintenance and Repair Forum
Tuesday, August 09, 2005 12:22 AM
Message title pretty much says it all. The previous owner of my car pulled the DRL relay, and also pulled the driver side bright, and fog lights esentially. I've got a new relay, but I don't know where it goes. Any help is greatly appreciated.
Re: 99 Z24 DRL Relay Location
Tuesday, August 09, 2005 7:55 AM
When you open the drivers side door look to the left of the gauge cluster on the side. You should see a thing that says FUSES. Open that up by pulling out on the little handle. It is the only relay in there. There is also a little map as to what fuse is what and it will say DRL Relay also.
http://members.cardomain.com/scrawnyguy18
Tuesday, August 09, 2005 11:15 AM
Thanks, my Cavy had the map taken off of the fuse panel, as well as from the top of the relay panel in the engine bay. I'm seriously not this much of a dumbass usually. Thanks again though!
