Well before i go outside and get mad i would like any info you have on doing tune-ups on 97 2.4L Z24. I have been doing things on Camaro's my whole life this is only the 3rd 4cyl car i have owned in the past 10 years. How do i get silver bar (looks like fuel lines and fpr) out of the way to acess the plugs? Any help or websites links would be helpful! Thanks
Carlton Jr,28 years old,Blk male
2001 Camaro SS #5780-Onxy Black M6(3:42)
grey interior(T-Tops)SLP Dual Dual,Slotted Rotors,clear corners,Hurst,SLP SS Grill,SLP Lid+K&N,Crane 8mm wires,free mods
306hp 327ft lbs tq.SAE BONE STOCK 1-21-06
1994 Camaro Z28 Mystic Teal A4(3:23)
grey interior(T-tops)Cold air intake w/K&N Filter,1LE elbow,tranny cooler,blaster coil,8mm wires, airfoil,clear
corners
1997 Cavalier Z24 light green mettalic m5
Cold Air intake,clear corners
The Spark plugs are located under the cover on the engine that says 2.4L Twin Cam just take out the four bolts and rmove the ignition harness the plugs into the cover and gently pull off. You will need and extension on your socket wrench to get to the plugs.
thanks alot! got it all done only took about 20 min!! Again THANKS!!
corners
