general Pontiac problem? - Maintenance and Repair Forum
Saturday, April 16, 2005 11:45 AM
I have a 1990 Sunbird which for 152,000 miles has run and started flawlessly. Today on the other hand there is a strange problem. When I went out to start the car it just clicked. So I had a freind help me jump it. after an hour of trying to get a spark we finally juiced up my car. It ran fine for about 10 minutes. But when I popped it out of park and into drive the car just died. My brother had a 90 something Firebird that did the same thing, and thats why he sold it. Any of you guys know whats wrong with my bird and is it expensive to fix? thanks
Re: general Pontiac problem?
Saturday, April 16, 2005 12:25 PM
if it just clicks and will start will a jump, and will not continue to run with out a jump box it is probably your Alternator, and possibly you may need a battery too.
No this in not a common Pontiac problem, it is a all car problem. you have 150,000 miles, the alternator is way past it's expected life.
If the stater just clicks intermittently it can also be caused by a worn starter.
Parts wear out.
<img src="http://geocities.com/jimmythekid1/gecat.jpg">
Saturday, April 16, 2005 9:30 PM
Ron Love Online
Yeah like u probably need a new alternator.U should use a multimeter to check ur voltage at the battery,starter and alternator to assure u have at least 12.5 volts that will alloy the car to run but,13 volts is preferred or higher.My guess is the alternator is not charging at all enuff to alloy the car to run all the electrical stuff like the ecm,sensors etc and the car will shut down due to low voltage.Check the alternator first its seen its better days more than likely.
Monday, April 18, 2005 7:49 AM
well I had my friend help me find out the problem. We used a test light and found that there was a constant draw of my battery. When I opened my door a weird buzzing noise came from the lower left front end. We never figured out what it was, but my friend did stop the draw that was on my battery tho. Anyone know what the heck that buzzing noise is?
Monday, April 18, 2005 12:45 PM
bumble bee? i have no idea..
Monday, April 18, 2005 2:30 PM
door buzzer maybe?
<img src="http://geocities.com/jimmythekid1/gecat2.gif">
Monday, April 18, 2005 3:07 PM
parasitic draw will not cause a car to not stall.
Monday, April 18, 2005 3:15 PM
just get a new alternator anyway, if its not dead your lucky
---1998 2.2 Cavalier Automatic Red---
<img src="http://www.softtouchsewing.com/banner1.jpg">
-Evidica-
Monday, April 18, 2005 9:04 PM
it could be your coil pack. or your tcc senoild..
they went on my 90 cause her to stop running.. when it did run she ran then went i drive she would shut down, stall out.
OEM CAMBER/CASTER KIT 10 People for $210 <P>
GOT ECOTEC?
Tuesday, April 19, 2005 3:41 AM
what does a Torque converter clutch have to do with the the car running? IF the TCC was bad you only would not have lock up. And a coil pack will not cause a no crank.
