is a 2001 cavi supposed to have an accessory mode when you turn the key backwords?? cuz mine doesn't and i just had a new ignition put in it.
www.mindflayer.net/images/happybunny.
my 99 fire does... I would assume so.
"i promise we won't get drunk, and go out in boat in the dark, stand up in the boat and fire the gun into the air unless we have life jackets on."
mine has it...in ACC,OFF, FIRST CLICK FORWARD, and ON, I can pull my key out...dont think thats supposed to happen...i can move the switch to off where you would normally remove the key, but have to put the key back in to move it from off...
HONDAS ARE LIKE TAMPONS…EVERY PU**Y NEEDS ONE!
It doesnt work after an aftermarket radio is installed, atleast it didnt in ethier of my cavs
Bruce
red03ecotec
thanx, it does have an aftermarket radio in it, so that probably is the problem
