starter not cranking over - Maintenance and Repair Forum
Friday, November 16, 2012 7:56 AM
ok so a 1999 sunfire gt. when i turn the key to start all it does it shut off the radio and the needles on my guages dim, it wont do anything else. no clicking or turning over. thats it. anyone know the problem. maby the clutch position relay whent bad???? awnswer as soon as possible. and if u want you can txt me at 270-485-1909
needing awnswers as soon as possible!!!!!!!
Re: starter not cranking over
Friday, November 16, 2012 8:06 AM
Prolly look at a bad battery.
Friday, November 16, 2012 8:16 PM
Ron Love Online
That sounds like it is time to buy a multimeter and do a voltage test,and OR jump start it and drive to auto zone or advance auto and have a charging,electrical check for maybe a bad alternator or battery,or maybe something as simple as a loose ground wire or cable going to battery.Basic thing based on your post and cold weather and hot can kill a weak battery and or alternator.I just replaced a battery today in my mother in laws civic,getting weak NO sign but green eye was dim and did the checks and kind of low.Once I took the battery and got it load tested it def failed! 4 yrs old so consider that.
Saturday, November 17, 2012 4:06 AM
As stated you need to do some testing.
have you tried jump starting the car? If so what results?
If you can get ti started then take it to local parts store and they can come out and test the charging system to find the problem.
Saturday, November 17, 2012 8:29 PM
I feel really stupid now but I found the problem. The clutch pedal was only pressing the clutch position sensor half cause my floor mat and wasn't letting the starter crank over.-_- simplest things at times.
