Ok, now i have no clue if this battery has just sat for too long and is dead or if it needs a certain way of being recharged. i have a small battery charger on it, on its highest setting (6V) and it wont go past 25% charge. Its been charging for like 4 to 5 days now.... do i need a bigger charger? ive seen on the optima website they have a 12V charger for like $200.... my problem is i dont have $200 to drop on a charger just to find out that the battery is dead dead, not just in need of a recharge. what do i do???
Straight lines are over-rated In My Opinion =]
Not all chargers are capable of charging an AGM battery.
Here is a bit from optima themselves on the subject.
Linky
Want hub spacers rear disk brackets or trailing arm bushings? Shoot me a PM.
Thx man, you might have just saved me some cash lol
Not to mention that a 6 Volt Charger will never charge a 12Volt battery to begin with.
Or take it to autozone or advance for a free charge there charger maybe able to charge it unlike a say normal charger.I would call them first to verify they can tell you being they both sell the optima stuff.A thought on the subject
You should find a good 12v battery and hook it up to the optima in parallel, Positive to Positive, Negative to Negative and then you can hook a smart charger up to the good battery and it should charge the optima back up cause some chargers will not charge a battery below a certain voltage. I have a yellow top in my car too and I love it so far!
2002 Chevy Cavalier Coupe 2200 SFI 5SPD Manual with 91450 miles.
Oil changed: 89616 miles with Amsoil 5w30 Signature Series and Amsoil oil filter.
Yep I found this out when working at the parts store, you have to use a trickle charger on them or you will overheat the cells
