So my horn has been out lately and I replaced the fuse as well as the switch but nothing worked. Well I removed the cover and this is what I found.
Can I please get some photos so I know exactly what its supposed to look like wired up properly? I tried inserting that detatched red wire into what seems the correct slot but it doesnt stay in. Thanks!
Shove into slot, give it a quarter turn. If it's not staying in, use some duct tape to hold it in place.
It just sits in there. No snaps, or anything. I just sat mine in there, and slowly put my air bag back on without the wire coming back out of the hole, and tightened the air bag down, and mine worked fine. Hope this helps.
"If I'm not back in 5 minutes...just wait longer"
Thanks for the help but even when I hold it pressed in and push the horn it still doesnt work. Do I need the air bag fuse in order for the horn to activate? Keep in mind the relay switch is new and I put a new fuse in the cig lighter slot.
