Nut Lodged in Water Pump Housing Help! - Maintenance and Repair Forum
Monday, May 14, 2012 5:17 PM
So, I was in the process of changing my exhaust manifold gasket and when I took one of the bolts out it fell into this little slot and in the process of trying to get it out I have only lodged it deeper. Am I safe to just forget about it and get a new nut or try to get it out?
Thanks!
Re: Nut Lodged in Water Pump Housing Help!
Monday, May 14, 2012 5:22 PM
get a magnet pen
Monday, May 14, 2012 5:25 PM
Already tried lol it's really stuck in there.
Monday, May 14, 2012 7:58 PM
Ron Love Online
Well I might suggest using a claw type screw driver (if that is correct).They make a driver with a bent angle tip like a awl that might give u better digging angles or maybe some strong clothes hanger wire or stronger.If it just a open point on the metal and won't hurt after really trying leave it.Unless ur bent on getting it out.A straight awl (if that is correct spelling) that might break it loose over any straight screw driver obviously.Just a thought
Monday, May 14, 2012 9:07 PM
I know it is a little extra work, but I would be tearing into that if I could not get it out from that opening. It will possibly not cause any damage, but I still like to be on the safe side in case I'm wrong.
Monday, May 14, 2012 9:19 PM
I can't be the only one that saw this on the front page and though "That's gotta hurt!"
I have nothing useful to contribute, really. Just thought I would share.
2010 Honda Fit LX
Tuesday, May 15, 2012 6:13 PM
Thanks guys for the responses. I still cannot get it out and I really do not want to pull the whole assembly apart, but we'll see. Could anyone with an ecotec go check and see if that hole is filled at the bottom or does it lead somewhere? Thanks!
Tuesday, May 15, 2012 7:24 PM
Wait...you want someone else to rip apart their housing? Just unbolt it and get this over with. Guarantee you won't make this mistake again.
Tuesday, May 15, 2012 7:39 PM
Lol no. No one needs to rip it apart you can see it right from the top.
Tuesday, May 15, 2012 8:16 PM
you could also go to an auto store and look at one to get an idea on this.
Wednesday, May 16, 2012 6:53 PM
It's what, under ten bolts to take off that water pipe? Just take it off and get it.
Wednesday, May 16, 2012 10:44 PM
So I took out that pipe, but there is a plate inside preventing me from getting inside the housing. Any ideas on how to get the whole housing off?
Wednesday, May 16, 2012 11:18 PM
After digging around I think this hole might be the "weep" hole. Could anyone confirm?
Thanks!
