Any one out there have troubles w/power windows?, my pass. side goes down fine, then when i go to raise it it goes about an inch then stops, have to wait for a minute then try again and same thing about an inch or 2, any ideas? Thanks
sounds like the power window motor is going bad...
I second that... the motor is shot...
yup your motor is going bad for sure. my driver's side went out doing the same thing your's did. bout a month later the passenger side went out. replaced both.
bout 2 months after that back passenger went out, manually got the window up, pulled the plug on the bad motor, did the same thing for the other back passenger even though it was'nt going bad yet and said @!#$ the back passengers.
i got tired of replacing motor's.
Try slamming the door. If the window goes up just fine you could have a loose motor not getting a good contact for the ground. Had it happen before to me.
