I have a 01 z24. Need to replace front left wheel bearing due to lots of play.
What si the axle nut torque spec in ft pounds?
and is there a torque spec for the torx on the hub itself? I've heard its 144 foot pounds. Correct?
thanks in advance.
"A goal without a plan is just a wish"
144 for the torx bolts is WAY to much (don't no the actual spec but common sense should tell you on a bolt that size it'll most likely snap)
70 FT LBS for the hub and bearing assy to steering knuckle and 185 FT LBS for the axle nut.
NCR-SCCA
i was thinking that 144 would be way too much, but thats what some site said whe i searched it.
but alrightt, thanks alot
That's straight out of the Haynes manual.
NCR-SCCA
.5 FAST CAV wrote:That's straight out of the Haynes manual.
^^^^ best $20 youll ever spend!
EYEOPNR (sleepercavy) wrote:.5 FAST CAV wrote:That's straight out of the Haynes manual.
not its not.. the best $20 spent was on my shop manuals for the 1999 years lol
Yeah! I found service manuals for my 94 sunbird on ebay for 17.95 !! New they are around 80 bucks. With shipping and all about 23 and change!
