i decided to put a stock 2.2l in my 95 sunfire, and there is no spark, stupid question, i know, but what would you say it is? I haven't been able to borrow a scanner to find out, just checkin if any of your have had this problem before, (every wire is hooked, and the coil pack is fine)
Is the fuel pump turning on also? Injectors putting out gas? I would have to say a ground somewhere. But if the pump is kicking on and the injectors aren't pulsing while cranking the crank sensor either isn't plugged in or bad. If it isn't plugged in the pump will kick on but no spark or fuel out injectors.
