Idol Problem - Maintenance and Repair Forum
Idol Problem
Sunday, September 02, 2007 10:10 PM
I did a search and couldn't come up with it..
well when I start the car it idols high then goes down to about 1 k... which is normal...
but when I wait a bit, it kinda blips... the rpm goes down a slight bit and then back up...
This is only when i'm stopped at idol. You can even feel the car kinda hickup...
Stopped at lights... just happens at any idol situation all the time
any ideas on what it could be???
Injectors? Vacum leak?
"Silver 2001 Cavalier z24 5 speed 2 door sunroof and power everything "
AEM Short Ram Intake
B&M Short Throw Shifter
Re: Idol Problem
Sunday, September 02, 2007 10:27 PM
Cursed Cav Online
First off, maybe if you spell "idle" correctly, you may get some hits when you search. Doubt you're going to find much with "idol". Maybe American Idol.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Re: Idol Problem
Monday, September 03, 2007 5:08 PM
Luke Heier wrote:First off, maybe if you spell "idle" correctly, you may get some hits when you search. Doubt you're going to find much with "idol". Maybe American Idol.
well I'm having an American idol problem too lol
Re: Idol Problem
Friday, September 07, 2007 1:50 AM
Clean the throttle body with throttle body spray, then do the same to the IAC mounted to the side of the throttle body. While you are cleaning the TB, keep an ear open for idle changes while spraying outside the TB, that may indicate a leak.
