Whats The Most Common Reasons For This Light Coming On? Thx
Loss of traction(duh),clicking up one on the e-brake,and putiing the shifter into 1st or 2nd.
It Just Came Onin The Drivewaysitting Still
search box-type in ets light,use the drop-down feature to exclude replies then hit the search button again
I could be a bad wheel speed sensor. I had one go bad and as soon as the car would move it would trigger the trac off and service light.
Would It Damagethe Car To Drive With The Light On ..Thx
If it was a wheel speed sensor, you'd most likely have an ABS light as well...
You can drive with it, yes.
Matt Linke wrote:If it was a wheel speed sensor, you'd most likely have an ABS light as well...
mine never went on when my wheel speed sensor was bad.
If the trac light goes on, for me it tells me something is wrong, 1. my cooling fans will turn on even when the engine is cold and ac is off, my car shifts really hard, and then finaly my trac light will turn off, then evently a check engine light will appear.
or it could be what they said.
ya i got the same problem as well...i believe it might be the abs speed sensor..i turn my wheel slightyly sitting still and abs light service light and trackion light comes on..you throwing it in drive they come on to..
check the IAT sensor (the small sensor plug on the intake tuibe... might be the case... not sure though...
