guess this is the right section....
like the title states....the motor just cut out two times....Started it up and it died after about 5 seconds of running...started it up again and it died again....started it up a third time and gave it a good rev and it held the idle....any ideas? happened once before at at a toll plaza too
oh yea....its an 03 2.2 eco in a sunfire with 48k on the clock, had plenty of gas
thanks guys
I've had it happen from stoplights and mostly mid summer. Ever since the recall reflash I've only had it happen once.
Best advice, pull over, turn the car off. count to ten, start it back up, should solve the problem.
-Chris
but do u know whats causing the problem.....i cant just count to 10 at a toll plaza....people have died for less
Chris DeNisco wrote:I can't just count to 10 at a toll plaza....people have died for less
Count real fast......j/k
If it is only occurring when the engine is idling, you might want to try cleaning the IAC valve.
ok cool....thanks for the help
Could have sucked up some bad dirt from the gas station, Got into youre gas tank. plugged you fuel filter, In which has happen to me be for.
