My right turn signal is not working anymore . I've checked the bulbs and fuses but rear is not blinking but the front is . Inside the signal is flashing fast as if there is a bulb missing . Anyone have any input on how I could fix it ?
could try a flasher unit or a relay, theyre not much money
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
You say the rear is not blinking? If so then change the bulb, the signal/running lights uses the same bulb, theres just 2 elements inside the bulb. Sometimes the element can look of from the outside but its actually not. Try changing the bulb first
GM had a recall for this, the tail light sockets go bad and need to be replaced. FEAR not! The new socket at the dealer is only about 10bucks a piece.
Good luck hope this helps.
Thanks for the help let you know after the weekend.
The recall your talking about might help if it was the correct year car
That recall is for 03 and up i believe.
