Ok. when i was replacing the timing chain, the cam moved on me, and i couldn't get it back where i needed it. My chiltons says somethign stupid about BLah Blah BLah timing allignment GM tool thing.
Whats the alignment procedure on the LD9?
And why does it have to be stupid, i know there has to be marks, i see marks on my cam and crank but i dont know propper alignment.
nwuonline.com
Proud member on JBNW.org
JBO member since 2004
you can put a bolt in the cam gear to lock it.
Gilles
2.3 Ho
ok, but since the cams moved on me, where do i set them at when the engine is at TDC?
nwuonline.com
You have to put the mark on the crank gear in line with the mark in the timming housing (12 o'clock). Then you set both cams (with a bolt, M8 if I remember correctly) in the right spot. Put the chain on with NO slack between both gears and between the intake cam gear and the crank.
Gilles
2.3 Ho
i guess what im asking is, where is that "Right Spot" I know how to time it, i just dont know where the cams go. I have the crank lined up, but how do i line the cams up?
see what im asking?
i know how to do it, just know where to put it. Theres a little hole in the cam gears, is that supposed to be the timing mark? Im about to drive over and get my other engine, and tear it apart and see where the cams are in relationship.
nwuonline.com
the little hole in the cam gear goes with the hole in the timming housing. The both line up. The exhaust cam is close to 5 o'clock and the intake cam is like 7 o'clock.
Gilles
2.3 Ho
ok thanks a bunch on this one. ...Back to work
i couldn't beleive they wanted 50 bucks for 2 pins on a cable.
Thanks for the help.
oh yeah opne more question, how do you get hte tensioner shoe out, does it come out as a whole or does the just hte outter shoe come off?
i have the actually tensioner plunger out, but no the whole thing, it broke too, need to replace it.
nwuonline.com
