I searched and found nothing. I found the headlight changing post though and I'm going to go change those now. In the meantime could somebody explain a little on how to change the foglight bulbs in my '02 LS sport? Thank a lot in advance for any help.
Eric
"An okay movie is the same as an ex girlfriend...it was good at the time,
but you never want to see it again... especially if the movie was a bitch."
Fog lights are easy. On the LS Sprot, I belive there is a peice of plastic at the bottom of the bumper you will have to pull back. Reach up to the fog lamp and twist the bulb out of the housing. Disconnect the harness. Take the new bulb out of the package making sure not to touch the glass. Twist it into the housing and connect the harness and you are good to go.
