Im not really a body guy but I want to experiment with some things.  What grit paper should you use for what?
As an example I have a stock spoiler that is very oxidized.  What grit should I use to smooth things out before primer?  then after primer?  first coat?  before clear?  The only thing I know is start with 1500 (wet sand) on clear coat and up to 3000 depending on the quality of finish you want.
Any help would be appreciated
240 before primer and 320 after primer. You shouldn't have to use anything between coats of color and for clear. Use a tach rag after each coat of color, never for clear coats. If you do need to sand between coats use 400-600 grit wet. After clear coats it's up to you but 800 or 1000(wet sanding) followed by a three step buffing process before the clear cures is normal. It's tougher to buff a cleared part after 24 hours(or whatever is stated by the manufacturer).
Now if you are rattle canning this I guess sanding between coats would be best. If you are spraying metallic or pearl, NEVER sand between coats.
Hope that helps some. Good luck.
